I am getting rid of one of the 340's I have to help my son with the finishing of his Dart Sport. I have decided to let the 6-29-1970 block go. It is a std. bore and there is absolutely no ring wear on this block. I have had this block for many years. I picked these parts up from a guy in the Cleveland, Ohio area. It came out of a 71 Dart Swinger I was told. I purchased several 340's and a 4 speed along with a lot of misc. parts from him. I have pulled it out and cleaned it up and painted the block. This is what I know about the block. The numbers on this block are as follows:
date code:6-29-70
pass. side rail : B223643
2780930-340-5 : side of block
left side below deck : CW340P34000365
The correct bolts for the timing cover is missing. I have 2 bolts in it right now to keep it on. I still have the cam and lifters that was in the engine that will go with the engine if you want them. They didn't show any wear on them at first glance. $600.00. block is located in Dry Ridge,Ky.
date code:6-29-70
