My little /6 is not firing the points is good and everything checks good. Anything that it could be?
No fun intended , But did you put your rotor button back on!!
I have dun this many times
So when you turn your key to the run position "not start position" check
for power to your points, How long has it been since the motor has ran?
It could be dry cylinders if it has not ran for a long time that would be low compression. When did this problem start?
Can you see spark from a spark plug?
Gas fowled plugs, Balist resister, Bad rotor button, or cap.
Make sure you have at least 12.full volts from the battery.
A week coil. I had a 63 /6 that would not start because it sat for a long time so I pulled the plugs and put a couple drops of oil in each cylinder and put the plugs back in after cleaning them!! and she fired right up.
It can be aggravating just take your time and make sure the timing is good.
Get your # 1 plug at the top of the compression stroke and see where your rotor button is pointing. Hope it did not jump time.
Just doing my best to help.
Bad gas or gas fowled plugs.
