68GTconvert
6 Pack Set Up - NOS Offenhauser 383-400 6 Pack Intake with 3 bolt flang(rare) with 3 Freshly rebuilt Ford Flat Head 94 Series Carbs. All quality parts were used to rebuild the carbs leather accelerator pumps, new pump springs, new pump discharge check needles. The middle power valve is a 5.5, the end carbs are blocked off. The jets are .051. Nice fuel inlets set up already. This will accept a stock mopar throttle cable. This was fabbed up to work. The throttle linkage was started to be fabbed up. It is close to being done or you can buy a new set up to make it work. This is a very cool set up for your hot rod.
$1100 obo
$1100 obo
