harvenator
A fish called Wanda
I have a new 600 cfm 1406 Edelbrock on my newly rebuilt 273. It has a D4B hi-rise, stock .030 over flat pistons, an electronic ignition and mild cam ( duration 240/240, .050 duration 212/212, lift .290, valve lift .435/.435, centerline .106/.114, lobe separation 110). My idle vacuum is 18" at 800 rpm. Fuel pressure 6 psi at idle, goes to 10 when goosed.
The car starts and idles fine. It seems to bog about 2500 rpm until around 3000 rpm and evens out.
I started out with a borrowed 635 Carter AFB which I rebuilt with the same issue. Figured that may have been too much carb and it might have been worn or had something else wrong with it. So I swallowed and bought the 600 brand new. Still had the bog, just not as bad.
I've tried replacing springs both ways (up & down) to no avail.
Thought someone out there might have already set one of these up for a 273 before and might be able to give me some insight as to what else I can try. Jets?? Metering rods?? I don't want to just start throwing money and parts at it.
Thanks,
Harv
Thanks,
Harv
