63-66 Dart. How wide of a tire on the back?
14x7's 4.625 bs 245/60's
They fit nice under my Cuda too
I love to see more of that 66 rear end/tire combo......it's that a 8.75 rear? Did you cut it? Iam guessin you r using mini tubs for that 275 tire...thanks
Stock wheel wells no cutting at all, 15"x8" rim with 4 7/8" b/s, i didn't like the look of the rallies
so i sold them and went steel rims, I got about 1 1/2" space between the wheel lip and tire and about 1" to the spring.And yes it's a Abody 83/4.
On my 66 dart P245/60R14 on the rear. 6 1/2 inch wheel with a 4 1/2 back space. Same wheels on the front, just clears the upper control arm. different sized tires on the front. Less then a finger clearance on both sides rear, and about 3/4 from the rear springs. No modifications. Wont get a bigger 14 inch tire in there without modifying :burnout:MT
What size tire did you put on front?
