63 Dart /6 transmission line routing
petty437
Kent, Ohio
Looking for pictures of factory routing for the transmission lines for my 63 /6 Dart. Anyone?
Thanks!
Yes I know. I actually found a NOS filter for cheap! Got lucky on that.
Here's a few I took when I was reinstalling my intake just after buying my car. Not specifically on the transmission lines but it should give some help.
Excellent, thank you.
Question is the bracket bolted to the pan bolts or is there mounting bosses on the block? I am really thinking of adding this back on my 63 as it has a later PB transmission and this is gone.
Pretty tough when the body shop pulls the motor and the lines & I didn't take any pics! DOH!!!
I must admit, no way would I have ever thought of routing them up around the motor mount like that. I would have gone straight under the oil pan rail with a bracket or two coming off a couple oil pan bolts and been done. Leave it to Chrysler to do something crazy.
Bolts to bosses on the block
Thanks. So do I have everything I need on my '68 225 block here to bolt it on if I can find a bracket?
Unless you're doing a snooty "points" type of restoration or otherwise have a hardon for extra-super-perfect originality on a pre-'64 car, messing with that inline filter is a needless hassle, dead end the next time you need a filter, and two leak points. See here for what you might want to consider doing instead.
