63 Dart Window Pivot
ARuiz28
Active Member
Camby, Indiana
Anyone have or know where I could find the little metal piece that connects the wing pivot to the window frame? Currently I just have cut cable ties in place just to keep it from flying off while driving. :BangHead:thanks fabo.
I might have 1 or 2 floating around in my trunk I'll check tomorrow.
If its just the pin you are missing, i found a stainless pin at Ace/True value that was a perfect fit. It was a few years back, so I am not remembering the size.
Chewy's idea for repair sounds like a good one. You really have the incorrect part. Hardtops and Convertibles use a male (built in stud) external wing window bezel while all sedans (2dr, 4dr, & wagons) used the female style in your pic.
