64 cuda original rear end
Garry
Louisville,ohio
Does anyone know where I can find a new spider, shim kits and bearings too! All from one place would simplify things. Thanks a million.
Hey Badsport I called Cass He is going to check with his supplier to see if the slightly newer gears will work. Bearings and shim kits ..no problem.
Does any one know if the new diff. internal parts kit (side gears,spider,etc.) "C" clip design will fit this odd ball 1964 early 7&1/4 rear. It has the pressed brgs. Cass said it is not listed as going back that far , but it doesn't mean that it would not fit. Hate to buy & ship here and not work. He can't take it back (special order)
If you want to take a little drive I have a complete '65 3.23 for $125. Has only 57k from a CA car.
thanks for the offer Signet. I will keep it in mind, I am trying to stay all original. I do have an xtra 71/4 rear to take apart & see if it is any better.
