Back in Time
I have decided to sell my 64 Dart project car. Paint was stripped and car was shot in Epoxy Primer. Car has spent it's entire life in Arizona and has no rust other than surface rust that I sprayed with Rustoleum .Not much has been done mechanically other than installing new fuel pump, New heater core and new Gas Tank.I have a set of lightly used KYB shocks bought from a member here in the parts stash. The interior has new headliner,carpet and paint.Neon buckets and cheap seat covers because I planned to do a custom interior later on. This car needs some tlc from someone with more time and talent than I have. Engine seems solid although I have only driven it around the block a few times. The transmission is weak and should be gone through but does move the car and shifts like it should. It has a bad leak where the cable goes into the transmission. I'm sure I'm leaving something out so if you need to know something just ask. I'm asking $ 2500.00. Will add more photo's in next post.
Price Reduced to $2000.00 8/1/2018
