UDUST81
Hey everyone first off let me say thanks for the help, i appreciate it, well yesterday my dad calls me, says mom tried to take the valiant out yesterday and it kept dying on her, car is a 64 valiant 225, /6, push button 904, with no real modifications other than some sort of holley 1 barrel carb. for the 3 years theyve owned it the things been just the most reliable old car they, or frankly anyone ive known to ever have, turn the key and go.
well i get over there yesterday and you can start the car if you give it a bunch of gas, but if you take your foot of the gas pedal it will slowly idle down, and then die, if you put it in reverse or drive it will die faster, if you pump the gas over and over and over and start it, it will stay running without assistance for a very long time, then slowly die. any tips? we changed fuel filter, played with the idle screws, even swapped out the coil and ballast resistor, since i had extra laying around, in case it was some sort of electrical gremlin, although im pretty sure it is some sort of air fuel issue, perhaps something in the idle circut.
Anyways appreciate any help or tips you can offer thanks again!
