JDMopar
Like Bill said, you have to beat the snot out of the pinchweld lip in the tunnel. You know, just down from the engine compartment....where the bottom of the firewall ends and the floor pan are welded together. It's pretty tight, but a 727 will fit. The mount on a 727 is in the same place as a 904. The tailshaft is longer, and it kinda creates an optical illusion. Honestly, I've never had a cable shifted Torqueflite that didn't cause me some kind of problem. If it were my car, I'd do like someone suggested earlier in the thread. Get a later 904 with a slip yoke, and buy one of the conversion cables from Imperial Services to hook your pushbutton controls to the shift lever on the newer 904. Either that, or find a column shift steering column and linkage from a 66 Dart of Valiant, and bolt it all up. I even took a Slapstick shifter out of a crashed 74 Challenger once, and installed it in a 65 Cuda that I put a small block 727 in. I got brackets and all, and it was a cinch to put in. The hardest part was cutting the hole in the floor for the big linkage shaft to go thru. You could do the same with any 66 and up A-body console shift stuff. Then you could run a cable from your old Park lever to a remote hood latch off a later model Mopar, to have a stealthy theft deterrent! :glasses7:
