65 back-up switch lever clip & washer
wh23g3g
Georgia
Does anyone know where I can get the washer that locks the operating lever clip in place inside the steering column on my 65 Valiant? It wasn't on the car when I got it from the previous owner but it definitely was optioned with reverse lights. I still see the bracket for where the switch use to mount and I have the broken switch casing. I've scored an NOS operating lever clip but it doesn't come with that washer to lock it in place. I don't even know what it looks like or if it's special or what size it is. I need that washer and the switch itself so I can reinstall the column so I can move it around the yard while I work on it. It's a column shift automatic with cable shift.
I have all those parts you need. They're used but in good working condition. $30.25 delivered to your residence via USPS priority mail.
Thanks, Mark
I've already got the arm. So you have the switch and washer?
Yes, switch, washer, mounting screws, and the pin clip but the clip is broken. I would probably still work once it was locked in place but since you have a new one, I don't guess it really matters.
Is there a part number on the switch? If you can hold it until this weekend I'll be able to purchase them from you.
