[SOLD] 65 Barracuda parts
swing69
fightin' socialism
Central Socialist NJ
As I remove some stock parts; I will post the OEM stuff for sale here on this thread. All parts are locate in NJ (08610). All parts shipping is to be paid by the buyer. Pick up of larger items preferred. All parts are from a 1965 Barracuda, auto, no PS, no AC, no PB car. 273, 7.25 rear.
Car was sitting for 20 yrs.. parts are all considered cores unless stated otherwise. ALL PARTS SALE STATUS ON THIS POST! ! ! !
1) 2524961 radiator. boiled clean, 1 loose side strap at top tank (loose solder). no damage. core leaked at testing. Needs repair. Good if you are looking for an original marked, stamped radiator and want to fix it. $70
2) Original heater core. boiled clean, leak checked - no leaks - heavier construction and better fit than replacement ones. $40
3) Original floor shifter COMPLETE including; shifter NO CABLES, tunnel mounting brackets (cut at welds from the tunnel). $90
4) OEM 2 barrel carb with air filter assy (top and bottom) $80
5) OEM 2 barrel intake: $30
6) OEM 273 Adj. rocker assy., complete: rockers, shafts, pushrods, lifters adjusters $100
7) 1965 273 block, crank - (no timing cover or set, no balancer, no oil pan or pick up) PICK UP ONLY $75
8.) Stock push button AM radio INCLUDES plastic bezel (no cracks). no idea if the radio works or not. SALE PENDING (Note: tiny crack is bezel by radio attachement nuts. tiny....but present)
9) Stock 273 exhaust manifolds. as removed. $75
10) Stock 7.25 rear. sbp. complete drum to drum. $50
11) 273 cylinder heads. NO Rockers. (in other post) $40
more to follow....... PM if interested. thanks
do you have any outside pictures of front and rear for lights and grill parts . I would be interested on a package deal on aircleaner and valve covers and other missalainious .please pm me with a telly # and so I can get you my yahoo addy for more pics and where you are located thanks jon
Winston and all: I'm only selling what is listed. the car is not being parted out. Only removed OEM stuff is being sold as the car is being "upgraded".
Radio picts. dial plastic cloudy. dirty. speaker wire and power wire cut, but can be spliced into. Just as it was in the car. 2 hairline cracks in bezel inside pocket where radio mounting nuts go. no where else.
Block pict.
air cleaner and carb picts. sorry about my crappy camera that I dropped and "bent" the lens on -- -- its all I have for now! be aware the lens problem distorts the picts....
I didn't catch it was you swing . some 1 else had a blue 1 up for parts , and he had like 15 hits and no 1 has heard from him . is that the 1 I sent you the body parts for ?? post some pics
here are the 273 manifolds from the 65 Barracuda.
R: 2465769 L: 2465857
also: carb and air filter gone.
