65 Barracuda/Valiant Seat Placement Help!!!
scottylack
NEW JERSEY
Can someone measure me up exactly where the bucket seat holes go on these cars? Had the floors done and holes were not transposed. Maybe at least passenger side??? Really appreciate any help!!!
call in the next 2 hours i could tell you for a radio and bezel lol
1 608 837 4427its 12:20 here now
OK Scotty, here you go...
I measured from the rear floor overlap weld to the rear and the front holes, inside and outside, and fron the factory floorpan lip on rocker side of the pan. The measurements are a follows...
Outside holes... 17 15/16" and 28 11/16", both pulling from the rear lap
Inside holes...20 5/8" and 29 3/8" from the rear lap
Front holes..8 1/8" and 21 7/8" from the rocker side lap
Rear holes...8 5/8" and 22 1/4" from the rocker side lap
Hope this helps, and if you need clarification about anything, message back and I'll do my best to explain if I can!! Geof
hmmm...the numbers are coming in and they are off a bit from each other...anyone else?
