[WANTED] '65 dart 225 ci well type choke thermostatic coil spring
jeffrey356
Kimberling city, MO
Need a new well type choke thermostatic coil spring for slant 6,225 ci engine. This part fits onto the cylinder wall common to the intake/exhaust manifolds. Spring inside housing probably worn out. There is also a metal connecting rod from coil housing on block to the choke on 1 barrel carb. Crazy design. jeffrey356
REVISED: Need 225 c.i. slant 6 thermostatic coil spring for well type choke. Mounts to cylinder heads common to intake/exhaust manifolds. Would like the housing and carb link rod. The housing covers the coil spring next to manifolds and the link rod connects the coil spring to the choke lever on the carb. thanks. jeffrey356
