Hello everyone!
I've inherited my dad's old 1965 Dart GT. It was a neglected restomod 20 years ago and I'm trying to get it back in driver shape. It was an original 273 2 barrel / 904 automatic car but the current engine is a later 360 4 barrel. The 904 was built out (from what I remember) and it has an 8.25" 10-bolt positrac rear. The rear diff cover doesn't have a drain plug. I was going to change out the rear diff fluid but want to know if I need to do anything special for this rear-end? I was going to use 2 quarts of 80-90 oil but wonder if I need to get anything special since it's a posi? Also, should I fill the rear up to the fill plug (passenger side on pig) or is there a better way of knowing how much fluid I should put in? I have almost no experience with Mopar so any advice appreciated.
Thanks!
Thanks!
