With a 3 inch inboard relocation, a tub, and a narrowed housing, probably 14 inch wide tire. The problem you will have (and I have had this problem on my car, 65 Barracuda) is the tire will rub on the body at the lower front of the wheel opening. I run a 275/60x15 M/T drag radial. You will need to relocate the axel/wheel rearward in the opening. I put a 1/2 inch between the spring mount and the body. It's all dependent on diameter of the tire.
