65 Plymouth Valiant A body radiator swap 170 slant six
Deemo
Tennessee
So, I'm new here, but not new to classics. Only to Mopars. And I've had a few issues with my little Valiant slant six. But I searched high and low and couldn't find a swap for the radiator when mine decided to pee antifreeze out the front grill. Everyone was saying buy new, or find another. Well, I couldn't find another one. And being poor (by means of the wife saying no to a 300 dollar radiator) I decided to go walk the local junk yard.....and found an aluminum radiator that works. I'm pretty sure it came factory in that truck but make sure before you pull it. 23 1/4 by 23 1/4 perfect square and the inlet and outlet holes were on the right sides. This swap should work on the 64-65 darts as well. If the front gap is the same as my 65, it'll work on others also if it's a slant six. V8s I have no clue. Sorry.
Tools needed:
Angle Grinder with a cut off wheel
Small drill bit
Sockets and ratchet
1-1/4 hose adapter from the 1 3/4 Slant six thermostat housing ( hose will change size)
And a few hours
Radiator from a late 80s dodge Dakota V6
First, take your radiator out and cut off the brackets that mount the radiator to the core support. Be very very careful as not to cut the tanks on the old radiator, someone somewhere will want them. You never know.
Now comes the fun part:
Get your handy angle grinder out and hack off a little over 3 1/4 inches off of the passenger side mourning bracket. Picture below for exact measurement.
Once done, cut both of the brackets off at the top and bottom to get rid of the bendable tabs. You'll cut off about three inches on both top and bottom of both sides and then clean up the cut edges and paint the brackets to your choice of color.
Mounting the new radiator
So mine had a height issue, that was solved by simply cutting the nipples off the bottom of the new radiator. The new radiator measures 23 1/4 by 23 1/4 with the bottom tabs cut. Perfect fit.
The bottom hose will have to go on first with the radiator at an angle. It's a weird fit, and the hose should bend. (I replaced mine, might as well while your in that far with the clearance, better safe than sorry)
Once on, let's get it straight.
Put the drivers side bracket in place on the radiator and get it into position. Have your drill bit handy and poke it through the original bolt hole location marking the bracket on the top and bottom. Drill the holes and bolt it in place but don't tighten it down yet. Do the same for the other side, making sure that the radiator will not have any side to side slack. It should fit perfectly into place once you have both brackets bolted in loosely. Once your happy with the alignment tighten it up.
Now, the problem I had is the bottom hose is the same diameter as stock. The top isn't. Here's where you have to be creative. I ordered a hose that fits a 1 3/4 on one end to a 1 1/4 on the other. You can take two hoses and slide the smaller inside the bigger if your that cheap or need to rig it temporarily. It'll work. Once everything is fitted and tight, fill it up, and ride safe.
Temp is identical to factory so no worries.
Change your thermostat while your at it and gasket. Might as well while you have time.
Nice work. Note that '64 and '65 do not have the same radiator support panel. The hole for the rad core is much smaller in '64. Your technique should work for '65-up cars. That radiator lists out for Dakota '87-'99. You can get 'em brand new in a reliable brand for under a hundred bucks, or if you feel like gambling on TYC "quality", you can shave about $15 off.
Well, mine was at the house and the 64 dart in the junk yard looked close to mine. So I had the kid run over and measure when I found this one. Then run back and see if it fit in. Worked just fine. Just took some time to measure it out. But thanks. I'll remember that tid bit of info.
!!!!!!You found a '64 dart in the junkyard???!!:eek::eek::eek::eek:!!!
Yeah. Lol. What you need?? Body is mint too. 4 door white with auto. No trans no head. 225 block. I managed to nab the rear bumper, door locks, and a few knick knack pieces in the interior. Has no grill or from bumper. Gas tank is one of those new see through types. And the seats are ok. Frames are great on them, just recover and good Togo. You need something off it???? I'm in middle Tennessee and it's at a pick and pull. Look up pick and pull a part in tullahoma tn 37388. Search it up lol. I liked to have fell over when I saw it.
Thanks. Great find, and looks like it was designed for the car. Most radiators in newer vehicles are wide and narrow, so "no-fit". I filed away for next time. I wouldn't be worried about putting in a 64 and down car, as long as it doesn't bump into things on the sides. The core opening is narrower, but you still get more core area which can only help.
My 64 Valiant slant came with an unknown copper radiator. Could be from a Honda since had a "Honda"-label battery. It stands off 3/4" from the core support, which let me fit a new alum AC condenser in that gap, but made fan clearance tougher (had to use a nylon fan). Your approach looks better for fan clearance. You might even be able to fit a clutch-fan, especially a thin one from a 1980's M-B or Jaguar.
Re junkyard 64's, there was a 4 door Dart a month ago at the Sacramento PickNPull, and probably still there. Not listed on their website and had "84 Dart" or such written on the qtr panel. Small-block w/ intake gone, 9" drums. I grabbed the V-8 steering cross-member and chrome wheel-opening trim.
Re the Dakota radiator working on a small-block V-8, yes if they have the alum water pump (lower hose on passenger side), and even easier since no hose adapting since same 1.75" lower hose. Most all older U.S. engines use a 1.5" upper hose (slant included). I went the other way in my 65 small block since the new Autozone radiator (listed 1972 Dart) was apparently for a slant, though the 1.5" lower port comes out straight (not tilted like most slant radiators). That was easy w/ a rubber bushing (or a short section of 1.5" hose, as you found). I put the later alum w.p. on it (caused multiple issues).
