I did it several times. Not too hard. Even w/o a hydraulic jack, you can lift it w/ cheap scissors jack that came on many 90's cars and up. I wouldn't lift from the tranny pan since that gives a large cantilevered load. I lift under the oil pan, using a 2x6 w/ newspapers on top to distribute the load and not crunch the pan. Once up, slide wood between the (unbolted) engine mounts and K-frame to keep it up, then remove the jack. As you jack, insure you aren't bottoming the top of the tranny to the tunnel. You will see the engine stop moving relative to the car body when that starts. Check that your right engine bracket isn't bent like mine was, since a good time to bend it back on a shop press.
The bolts are 1/2" head I recall, and helps to have several wrenches and socket extensions. Be real careful when tightening the bolts that go into the rear aluminum seal mount. Many have been stripped, so check yours while out and you can Heli-coil fix it. Also a good time to change that seal (same as 426 Hemi, which has an upgraded part). Much nicer if you clean everything first. I use diesel, scraping, then engine degreaser (dollar store "LA Awesome" works), then brake cleaner and ethanol if going to respray while it is all purty. While the pan is off, you could also change the rod and crank bearings, if you have measured low oil pressure.
I recall using a silicone gasket from Real Gaskets (TN). It should last forever, but requires very flat surfaces to seal. Use a dab of silicone RTV in the bottom corners of the timing cover.
