"65" Valiant engine code
VIOLENT\6
12 second N/A Slant 6?
Massena, NY...Almost Cana
How do I translate the fender tag to find out which "Slant 6" is in the "65" Valiant I just bought for my son?
I was told it was a 170, but the small hose on top of the water pump looks a bit long for a 170. I think it's a 225. The car is supposed to be #s correct.
I don't believe there is such thing as a #'s correct car for this era as the vin #s were not printed in engines yet!
However, you should be able to check the fender code, to see if it was a 225 or 170 car.
Robb
Just like RobbAdams said I have seen them off before but still be fact installed.
Did some one change the water pump :drinkers:
Look on the block right next to the coil.There are some numbers stamped there.The first three is what your motor is.Hopefully it says 225. :thumbup:
It's a 225. The long waterpump hose was the tip off. The casting # confirmed it.
Joshua I had that very same Valiant, 1965 and color. It is a great car. It was easy towork on and it was a good reliable car.
