65 Valiant rear seat belt location?
V8-valiant
Central Oregon
I’d like to add rear seat belts to my 65 Valiant but there’s nothing there currently. Does anyone have locations for the seatbelts? What did you do to add/install them?
My 65 Valiant wagon has loops to mount, presumably from factory. Looks like yours are missing or were removed. I put picture of driver side rear. See yellow arrows on pic. I think it didn't come w/ rear belts originally (not 100% on this), but just the mounts. Funny, I was just getting ready to install belts this weekend. Ace Hardware here in town carries the 7/16 fine thread grade 8 nuts, bolts and washers.
This is a '65 Barracuda, but that should be the same. In the center there actually were holes already with a plugs in them. I had to drill the outer ones. Make sure you don't drill through the brake line - it's in that area on the driver side.
AP1GczMQICkC8H1--BKwnl2x8jB45EI-oZTL0X_k2tocOLrlX9Ty72Pq7NDN1h5WZ36KKaiZv3MnDTUEnUNY1lz0DAl7fsmQ3URW_MiBwhdxkJPIpwf2UOJw4AWlLO5_tBQXCqoEzLPyc-XsqkAnn-Tc7KE9qQ=w2554-h1916-s-no-gm
AP1GczO1Dq5wEETPQYl3J9QJO1M_LNT-MOzqNUjq9D8kooOEQ4mJCa3NTWXMkcWIPcB_NbFei5AEweTR0bQtg3NnkD-Xw5w0q1s1RmY1jjd9pzk7vXcGsC-kvOfO7UohikCHa1PrU2wsg_kZpW1LMghNhuIskQ=w2554-h1916-s-no-gm
I've seen cars without seatbelts and there were dimples. Had to drill holes and putting a backing plate/nut.
My 62 Valiant had seatbelts in the front with those loops, backing plate/nuts behind them, but they were directly behind the seats on the floor.
Right where rear passengers would put their feet.
Seatbelts were also clearly not factory.
I think you're going to have to wing it.
