[WANTED] 66 and EARLIER POWER LENGTH COLUMN
The two latest pre '67 Darts at the El Paso pick a part were both manual steering. So that means the Columns are shorter or longer? Just asking a question, not an expert here, more of a parts Generalist.
Power shafts are shorter due to the increased size of the power box.
Do you just need the length measurement? Do you want the whole column or, the center shaft with the P/S coupler?
63-64 shafts are the same. 65-66 shafts are the same with the differences noted in the picture. 67 shaft is different again, at least by part number.
The couplers evolved over those years too......from a band clamp, to a set screw, to a roll pin.
