66 Barracuda Fuse box
Pcamp
Member
halifax
Hello,
I want to remove the fuse box in my 66 Barracuda to change fuses.
I removed the screw nail but am not sure how to remove the box itself.
In mine if I unscrew the screw it comes down. either yours is wedged in somehow or mine is loose.
When you say "remove the fuse box", do you mean to disconnect it from the wiring, or, just to lower it down from the dash with the wires intact? As Jim mentioned, you can pull the fuses without doing either. What's the problem with yours? Why do you need to replace the fuses?
