340duster340
sorry have a bunch of questions, this is not a restoration so trying to re-work things a bit and open to suggestions
- with front sway bar (FFI) and large patter disc brake conversion, are you running calipers front mounted or rear mounted? and which brake hoses are you using? i will be running calipers front mounted as do not have factory sway bar tabs on my LCA and will be using their mounts that use the lower shock bolt
- rear sway bar, worth it? i was going to order it along with the front from FFI, anyone running one? and do you have exhaust clearance issues?
- e-brake cables, has anyone converted to the later style that runs passenger brake over to the drivers side, and single cable from the main ebrake lever to the rear lines that mount to the brake backing plates? i want to run subframe connectors and dual exhaust, so eliminating the cable on the passenger side would be nice
- shocks: are KYB really a no go? would i be better off with monroe until i can save up for bilsteins?
