bearwolf64
Bearwolf50
All
Should I set the timing at 5 or 7 BTDC?
Bear
Bear
Redfish- didn't you run that engine at 16 degrees BTDC right after the electronic distributor conversion? Seem to recall finding an old post to that effect.
When you say "advance disconnected", that's the vacuum advance, right?
I checked my '67 factory manual for 273 timing specs.
For non C.A.P. engines
Timing spec for a 2bbl manual transmission is 5 degrees BTDC
Timing spec for a 2 bbl automatic and all 4 bbl is 10 degrees BTDC.
All C.A.P. 273's are speced at 5 ATDC.
There are differences in the mechanical advance curves corresponding to the differences in base timing. My electronic aftermarket distributor (installed 1992) appears to have the 2bbl manual mechanical advance curve by default, but both mechanical and vacuum advance are adjustable.
So at 6 BTDC, I'm running close to factory spec for a manual, and so are you at 12 BTDC with an automatic
