[Found!] 67 barracuda driveshaft
what rear? your going to have to measure as variances happened. Just to prevent a cut and cry scenario.
If pishta don't get you fixed up, PM me, i have one from a 67 Barracuda with 904 trans
Moparparts. could you measure yours to see if Im in the ballpark. Im fairly close to him.
I have a 1967 Barracuda Formula S that I parted out. It had a 273 commando with a 904. I saved the drive shaft. Let me know if you want it. Im going to Carlisle, so I could deliver. Lou
Ive got one 47 5/8 to cap C/L's but I think its going to be too short as its for a 904+8 3/4
Hi how much for the drive shaft ,is it for the 8. 3/4 rear .
Tyler
Mine is the correct 67 2 piece design and is 51 5/8 inches C to C of u-joint, has 7260 ends and 2.75 diameter tube
Hi how much , is it for the 8. 3/4 rear?
Tyler
It was marked 67 Cuda from years ago by helpers here but from a quick check of lengths that appears to be the length for a Dart or maybe a B-Body, i will have to check the 67 Chrysler parts book lengths to see for sure what the measurements are. It does still have the original part numbered yoke
I have a few driveshafts laying around from different applications...
Let me know what length you are looking for and I can check...
Darts and B-Cudas have different wheel bases.
Some where I remember a chart that had drive shaft lenghths listed, for A-Bodies, with different components. Where i saw that I can't remember. I will look in my 67 FSM, and 67 parts book.
barracudadave67
OK
I looked in my 1967 FAC Parts Manuals. Section 16 "propeller shafts", page 16-1. B-Cudas were not listed as such, so I am giving the length for a Valiant. This is for a 273 eng, with an A-904, and 83/4 rear. it states 49.28 inches center to center.
I also looked in my 69 FAC Parts manual. section 16 "Propeller shafts" page 16-1. B-cudas with 318 engine, an A-904 trans, and 83/4 rear, is 49.27 inches. B-Cudas not listed with a 273, only Valiant, and that is with an A-833, lenght is 48.6 Again this if from the 69 manual.
You can call "Hensley Performance" in Knoxville TN., they are Mopar only, ask for Ken give him your particlulers. They have made drive shafts for me, and they know what you need. They race Mopars.
I hope this helps some.
barracudadave67
Tyler
From the 67 Chrysler parts book , stock factory application for a 67 Barracuda model with 7 1/4 rear and 3.23 gears is part number 2533192 and the shaft is 51.61 inches from C to C of U-Joints 2.75 diameter tube and has 7260 ends. This same length shaft was used on some other 67 Valiant and Barracuda models as well with 7 1/4 rear and other ratio's. This is the shaft i have that i mentioned in my previous post so it will not work with an 8 3/4. The 67 Barracuda with 8 3/4 rear and 3-speed manual, 4-speed manual or 904 automatic trans used a 49.58 length shaft that was 2.75 diameter and had 7260 ends the part number for it is 2781952 I have a lot of other shafts from later models and will check lengths and let you know if i have any others that would work
