JLP
67 barracuda Fastback
Factory AC car (disconnected)
360/727, 9.0:1 compression, hypereutectic pistons, Mopar performance 280 dur (advertized) .474 lift cam, less than 1000 miles on engine, less 4000 on trans
4 wheel disk brakes, 11.75" front, 11.25" rear
big bolt pattern (5 x 4.5")
8 3/4 3:23 suregrip
340 HP manifolds to 2 1/2" TTI exhaust with X pipe
Performance sway bars (1.25" front, .75" rear), "C" body tie rods, heavy duty ball joints, All new with less than 1000 miles on suspension, poly bushings, 74 K-frame with spool mounts
KYB gas shocks
Stainless steel brake lines, Willwood proportioning valve
Rust in right rear quater, have piece to fix from a 67 Barracuda
Has 68 hood , hood inserts, header panel and grilles. Have the original header panel but it needs work. Do not have the 67 grills.
New window seals to switch to 68 style (noyt installed
Stainless trim for front window that has been profesionally polished.
Other miscelaneous items
Car runs and drives
See http://www.jlpaasch.com/67cuda.htm for pictures. E-mail me at john@jlpaasch.com with any questions. Asking $5500 firm
8 3/4 3:23 suregrip
KYB gas shocks
Car runs and drives
