WAYNE0
Finally got the "water in the engine" issue taken care of. Got it running & set the timing & idle. The only thing im not to sure about is the "type writer" sound coming from the rockers. Its a hyd cam. Took the valve covers off & the left side doesnt seam to be getting oil like the right side. I doubled checked to make sure the rocker shafts were on right. Sounds good & has good oil pressure. I set the idle mix screws. Now the next step is to set the float level. The carb has the clear sights. The next thing is to get a drive shaft in it & see if it moves. The front yoke i have was suppose to be for a 727 or 833. When i went to put it in it wouldnt go fare. Here i noticed it has key way. Not sure what its for. Never seen one like that. Also as soon as have the spare money i have to get the bracket for the master cylinder to go from 4 bolt to 2. Then i can bleed the brakes. After all that on to the interior
