67 Barracuda Formula S
bfisherco
New Member
Milliken, Colorado
Greetings !!
I have been offered a 1967 fastback. It's what the title says, and I was called and told I could have it for cheap. Yeah, it needs work and lots of it, but it isn't a total basket case. Actually, I don't think anything's been disassembled and it's all there.
It has the original 273 motor and a 727 tranny, all glass intact, frame straight, little bit of rust and a huge dent on the passenger side. Front clip good, door metal hit hard, rear quarter has a big one below the window. The driver's side metal is good. All the trim and badging is there.
Is it worth it? What would make it "unrestorable"?
b
Depends how much money you're willing to spend !! It may not take as much as you may think if you're capable of doing a lot of the work yourself !! GO FOR IT,you only live once !!
completely rotted out frame rails
or bent like a pretzel
at least that is what would make it un drivable again
un restorable is a matter of opinion,
what do you consider "restored"
Greetings !!
b
727?? I don't think the formula came with a 727 in a 1967 smallblock. Check the fender tag. What else was changed?
How much is "Cheap"?
Sounds like $20,000 just to get the body in order unless, you know how to do it yourself.
Un-restorable is just a matter of your budget.
Do you have 20k-35k to dump into this car?
You could get the 727A in a '67 Barracuda. All you had to do was order it that way. My first '67 Barracuda FB had the 727A with a 273 2V, 8-1/4" Sure Grip, and H.D. suspension, and was NOT a Formula S car. I bought the car off the original owner and that is the way he ordered it. He also ordered it with the Maroon interior with Pearl White seats and door panels.
