DallasMan2000
67 Barracuda with 1975 360 and electronic ignition.
Just bought this car two weeks ago from this forum and understood when I bought it there was some work to do.
So here is the issue…. When test driving the car it died and would not re-start. We originally thought it was a gas issue. Added gas and cranked for a while and engine would not fire. Suddenly it fired and we were able to get it back to the house. The engine would fire occasionally for short periods of time between then and when I transported it home.
Began troubleshooting in the garage with a test light, volt meter, and spark tester. This car has a 4 pole ballast and I get 12.5 volts at all 4 poles with the car in run position. Both the coil positive and negative get 0.632 volts with the key in run position. Picture of the ballast and a wiring diagram (from this site) are shown below. I unplugged the top plug on the ballast and got 10.5 volts coming to the right side of the plug (brown and blue wire) with the car in start position. Pin 1 in the ECM plug gets 12.5 volts with the car in run position. Positive side of the coil gets no voltage increase with the key in start position. Run a jumper wire from the battery positive directly to the coil positive and the car fired immediately. I have changed the ballast, ECM, and ignition switch with no voltage changes from those described above. There is no continuity between the top right ballast plug (brown and blue wire) and the coil positive.
Any ideas?
Any ideas?
