[WANTED] 67 Cuda Door Checks
Of the part, wish I could, The car is missing both sides.
The part that prevents the door from opening too far and holds the door open. Some call it a stay or check.
There is no such piece that does the job you describe. On the lower hinge in your pic is the only hinge control on these cars, the double wheel and bar that holds the door open. I thought you were referring to the wedges on the door jamb side that align the convertible doors when closed.
Thank you to all, I found a fix to my problem of the doors opening too far. Hinge was worn, nothing a little weld wouldn't fix. Thanks again.
NOW, for another issue. I'm in need of a left hand convertible top latch. Busted the handle.
I have a pair $60 shipped to your door. PM me is you want them.
