67 cuda turbo
nitrohemi
mountville pa
Thought I would share my 67 383 turbo cuda. I have an efi gold box with mega squirt controlling fuel and spark among other things. Making almost 10 lbs of boost in parking lot testing. Have some tuning to do but in the spring it should be on the road. Just got closed loop idle figured out. Next is cranking fuel as its a little hard to start sometimes. Been a fun project with learning megasquirt. 2 step and 3 step setup. Next will probably be a boost controller and e85.
I wish they would make left hand and right hand turbo housings. I must have symmetry!
They do. They’re called mirror image turbos. Patented by NRE and now copied by everyone else. My new 67s are mirror image.
Thought I would share my 67 383 turbo cuda. I have an efi gold box with mega squirt controlling fuel and spark among other things. Making almost 10 lbs of boost in parking lot testing. Have some tuning to do but in the spring it should be on the road. Just got closed loop idle figured out. Next is cranking fuel as its a little hard to start sometimes. Been a fun project with learning megasquirt. 2 step and 3 step setup. Next will probably be a boost controller and e85. View attachment 1716332372View attachment 1716332374
Nice. That’s right up my alley. Can you share a little more about the combo? Engine size, cylinder head, compression, what fuel, what turbos, etc. please.
383 with 906 heads. Pump gas for now but I plan on running e85 once I get the flex fuel sensor figured out. I believe they are gt45 turbos. I don't need to be making too much boost. 10 lbs. is probably the limit. Cam is around a .515 lift solid flat tappet. I would think the compression is around 9-1. Log style exhaust manifold I put together with intentions of building another set. They work although I think they contribute to turbo lag when I launch the car. Some of that may be in the tuning also. Once the boost comes in its a different animal.
383 with 906 heads. Pump gas for now but I plan on running e85 once I get the flex fuel sensor figured out. I believe they are gt45 turbos. I don't need to be making too much boost. 10 lbs. is probably the limit. Cam is around a .515 lift solid flat tappet. I would think the compression is around 9-1. Log style exhaust manifold I put together with intentions of building another set. They work although I think they contribute to turbo lag when I launch the car. Some of that may be in the tuning also. Once the boost comes in it’s a different animal.
Nice build! Judging by those exhaust housings it looks like the smaller GT35 turbos which I would think would spool pretty quick on a 383ci.
