67 Dart 2 dr hard top Quarter Window
dave273dart
Green Cove Springs, FL
The right quarter window is tight with not much up and down movement, however the left quarter window moves about 1 or so inches up and down. Both window have all new rollers. Has anyone had a similar problem with their quarter window (s). I sure would appreciate any help I cant get. Thanks.
Dave
You thought that was funny. I am glad. Funny makes life more fun. The window is not too tight, it's as loose as a goose (as I said, it moves up and down more than an 1") I think that there is too much movement on the left quarter window. The right window works great. I guess I should have explained it better. All the rollers are in the tracks. I have greased all the rollers, tracks and regulator. I will probably end up taking out the window, unless someone has had a similar problem and can come up with a solution. Thanks.
Dave
