[WANTED] 67 dart floor shift ps column
I'm not sure what you need exactly, I have a disassembled column (from a 68) but I might have the part you need.
Post a Google photo of the part you need.
The steering shaft that runs thru the center of the column
Make sure the steering shaft you buy has not been collapsed.
There is some plastic that connects the upper to the lower section and if someone beat on the shaft they most likely broke the internal plastic
