67 Dart-to 71 Dart?????
Yellow71
Member
I picked up a 67 Dart GT slant 6 parts car. Will the manual stearing box and drag links and everything else fit on my 71 Dart V8? I want too go from power to manual.Any help THANX
box will work, but the idler arm is different on the 67 than the 71. Not sure if the center link is different, but I think all will work but the Idler
you going to part the car out? is the trim still on the trunk? right tail lightgood?
If you want to sell it please contact me
99WildCat@comcast.net
I think so. You'll have to overcome a difference in how the idler arms are attached at K-member and also change the steering column.
You'll be switching to a odd and expensive pitman arm though. Lets hope the donor is a good one . :)
the trunk trim is kinda shitty,it has a GTS tag on it. The tail lights are pitted,needs new chrome but the lens are decent.
