[WANTED] 67 fastback window regulator
QKFSH67
Prophetstown, IL
I need the right rear regulator, also need the black clips for the front door glass, that hold the plastic strip in the wing window track. Thank you in advance..
I have the rear passenger window regulator, I'll go and check for the black plastic clips! The reg is from a 67, which is out at my shop, I have a 68 here, would the clips be the same??
Oops, only the 67 has a front door, and only the drivers side!! Looks like that will have to be tomorrow, the reg is here in a box tho!
G
Great...I would assume so
The only clips I can think of are the guides or shoes that hold the door glass in the forward channel. Those are in a kit that includes the felt laminated plastic strip. Approx' 50 bucks per door new.
I personally wouldn't go to all that effort to install used, especially in the drivers side / most rolled window.
