67 gas tank to a 68 69 one
davescuda
Cheshire, CT
My question is. Will a 68-69 gas tank fit in a 67? I know 67 have the single strap, but most of these aftermarket tanks have that strap in dented in the aftermarket tank. They are made to be universal. Is there anything else different on the 68-69 to the 67 tank
TGhanks
Yes, 68/69 with a single strap left to right indent will work just fine in a 67.
Not sure if real 68/69 tanks have an indent front to back for the dual straps????
My replacement tank for my 69 didn't line up with the indents, and they looked to narrow too. Tank was from Spectra.
68 and up do not use the indents. Just the 67 uses the indents in the tank for the strap that goes across the tank.
Where the straps run.......
I kind of figured it was a good thing not to as if they did they could rub a hole in the tank.
