sb3854
Active Member
Any advise on adjustment of the front door on a '67 Valiant 2dr sedan. I thought it was the pins but they are solid but the door is off about 1/4 inch. Help please.
Very helpful...worked for me!loosen the bolts on the door half of the hinge for in/out adjustment to the door.
loosen the bolts that hold the hinge to the body for forward/backward adjustments. you'll have to remove the kick panel for access to these.
it helps alot to have somebody help you and it will likely take multiple attempts to get it right. -pauly
