67 Valiant Windshield rubber/molding options?
JayWithanA
Member
Virginia
New to Mopars just got a 67 moredoor Valiant and cannot find the correct windshield and rear windshield rubber and molding anywhere.Seems like an off year for those pieces what have you guys done to solve that issue and or is there somewhere I can get them?
Try steel rubber? the 67 had a lock strip that fit in the gasket that lock strip is, if you can find one, very expensive. they are also prone to shrinking quickly. There are some alt lock strips that will work. not sure what as it's been a while since I did the research...
Or an option is to change them out for the 68 and up stuff and get the stainless moldings. I did that with my 67 barracuda. the weatherstrip are cheaper and the reveal moldings for the dart/ valiant should be more accessible
Lock strip on 67 Dart was $325.00 a set when in stock at Stephens Mopar.
Switching over to reveal molding isn't much better with addition of clips rivets and screws either.
Re-use gaskets and clean with mineral spirits. They clean up better than you think.
67 4 door glass parts are a pain in the glass!
The 4 doors no mater the year are harder to find glass parts than 2 door.
Good Luck. What a nightmare.
