[Found!] 68-69 A HOOD TURN SIGNAL WIRING CLIP...SCREWS TO COWL IN FRONT OF DRIVER
ph23vo
seattle
FOUND FOUND FOUND THANKS
NEED; WIRING CLIP LIKE THIS...68-9 A / B BODY..THESE ARE UNDERDASH, UNDER BACK SEAT, KICK PANEL AREA...ALL OVER,, NEED THE ORIG SCREW ALSO [ITS A SHEET METAL TYPE SCREW ..... NOT THREADED LIKE THIS PIC...] NEED A NICE ORIGINAL ONLY.... APPEARS TO BE MORE SQUARE THAN REPRO IN PIC [WHERE SCREW GOES THRU] REPRO IS MORE RECTANGULAR... THANKS
You could make that easily. Polish a piece of 18 or 20 gauge metal and then cut it, then file the cuts smooth and polish again. Then spray on a few light coats of rattle can clear for rust protection. Then dip it in that black rubber stuff that you can dip tool handles in. If done carefully, nobody would ever know.
I will take a look at what I have tomorrow and let you know. I might have some good ones.
THANKS...THEY WERE USED ALL OVER I KNOW I HAD MINE BUT TOO MUCH STUFF BOXED AFTER MOVING AND CANT FIND IT..LOL
