Looking for a PS column for floor shift applications. I need everything below the steering wheel to the box. If the TS switch is bad no issue for me. Color is not an issue. Mount brackets are not an issue. Replacing manual steer for power steer.
I think I have one still from a 68 I parted out several years ago. Ill see if I still have it tomorrow
After some research in the parts manual it would appear that the only difference is the actual shaft and shaft coupler. The parts manual also lists a specific shaft for each manual and power steer 383 cars. If it is from anything other than a 383 it may be an issue for me based on the parts manual. Thanks for the responses! Here are the parts for Manual steer. Here are the parts for Power Steer.
