68 Barracuda Notchback Deck Lid Mounting Hardware
Sound like you just need the correct mounting bolts yes?
Well the hinge is not threaded and the deck lid is not threaded, so I would presume there needs to be some sort of bracket that goes into the hole of the deck lid with the end of the hinge? I don't see how a regular nut would be tightened without it being on some sort of bracket. But I could be way off here so please excuse my ignorance.
Heres from my 69 FSM.
The parts you linked that slide into the hinges look correct but barracuda isn't listed. I dont know if the bolt spacing in barracuda hinges is different from those other a-bodies or not. Maybe email that vendor and ask for bolt center to center measurement, or just buy used from a barracuda. @barracudakid
