68 Dart Front End Re-Build question
waldrgd
Member
I am rebuilding the front end on a 68 Dart. I have the upper control arms, spindles, disc's, etc from a 73 Dart that I want to put on the car. My questions are. When I order the front end kit do I order one for the 73 Dart? Is everything compatiable except the upper control and spindles? Or do I have to piece one together? Should I use the poly kit if I will only be drag racing? Who should I order from?
Thanks
The idler and pitman should be 68-72 A-body. If you have a 72 and earlier steering box.
The upper and lower ball joints are 73-76 disk brake A-body.
So the tie rod ends, bushings, etc for a 73-76 will fit the 68? If so, I should order the kit for a 73 and order the pitman and idler separate. Correct? Thanks
