Where can these be had?
Soaked in PB blaster, but I think it's a lost cause. Time for nut splitter and move on with new bolts and nuts.
Thank youLower shock hardware, I put all that in a earlier thread. I recall flat washer and nut ( no lock washer ) but I forget the bolt length. Should be simple enough to figer out if you cant find that previous thread/post through search.
Torsion bar has only a spring wire as keeper behind it. The height adjust bolt is special, all thread ball nose not found in hardware stores.
