68 Dart question
Badart
Senior Member
Northern Utah
A friend of mine has his dart at the upholstery shop and needs some help. Is there some kind of support bracket that mounts behind the arm rests? I can't remember.
Other than these and the pads I don't recall anything else.
Thanks for the help. So there is not other parts other than the base and the pad?
Only the screws as far as I recall. I recall having to tap a hole to make it smaller because the screw wouldn't stay tight. I used a body dolly on the back and a body hammer and shrunk the hole. This was on a front door so I don't know about the back pads. Maybe someone will add to this and confirm what I recall id correct.
Yup, that's all there is...the arm rest pad, base plate, and screws.
Usually there is a metal clip in the door shell that the screw goes into.
