Here comes the list of nice stuff to come these days, I have Magnum 360 engine, and I've switched from manual to auto gearbox.
HU202AM HARNESS
392301978270 1968 MOPAR DODGE DART EXTERIOR SCREW KIT 60pcs
392275748462 1967 1968 1969 DODGE DART 2 DOOR HARDTOP INTERIOR SCREW KIT 105pcs
232433562147 TRANSMISSION COOLER LINE
173938646848 DUST SHIELD
281836874920 OIL DIPSTIC
362469608489 STUD KIT
MM2367 1960-76 Mopar A/B-Body 36 Piece Door Panel Installation Clip Set
MN1037 VALVE COVER KIT
273582705323 1968-69 Dodge Dart Mopar A Body Complete Power Disc Brake Line Kit Set OE Steel
320840510511 67-76 DODGE DART 2DR AUTO CARPET
401754183718 BOLT KIT
261941806798 INTAKE MANIFOLD
LOK-KDP-2727BLD KICKDOWN KIT
HED-78500 HEADERS
PWM-9513 STARTER
MEL-72-S2 OIL PUMP SCREEN
SUM-G3536 OIL PAN
SUM-221116 FITTING
DCC-P4876772 BOLT KIT
BSP-90820 THERMOSTAT HOUSING
EDL-1906 CARBURATOR
SUM-G1423 STUD KIT
GAR-56330-HSP BOLT KIT
TCI-141500 CONVERTER
TCI-743807 DIPSTIC
TCI-145200 FLEXPLATE
DCC-P4876820 BOLT KIT
2272 MOUNT
33036S THERMOSTAT
GMK2111749681S BOLT SET
IST97 FUEL TANK STRAP
CR11C FUEL TANK
TCI-111100 TRANSMISSION
M60514 FUEL PUMP
FG69B FUEL SENDER
Hope I've not overloaded the thread
and sorry for the not a historical sequence of the photo's, I'll fix it later on, now it should me more interesting as the assembly after the paint work has started.
