Hello folks,
I have some days off, so I started today with the brakes:
the front brakes are done = back plate painted, new cylinder, hose, new hardware and shoes (bearings are new - I did them a couple of weeks ago),
rear brakes are done also = new cylinders, shoes, hardware, hand brake cables (x3),
removal of all the rigid lines including prop valve, removal of old master vac and master cylinder.
Tomorrow I need to remove the right front brake line (which is somewhere on the firewall), and remove the dashboard to have better access to the handbrake cable attachment on the lever. Anyway, I am going to fit the Intellitronix gauge cluster, and a new steering wheel.
I will receive some fittings next Thursday (that were on back order), then I will install all rigid lines next week-end, and the new power brake.
I will have the valve (the one with the pressure drop switch) ultrasonic cleaned as well as the rear axle brake hose T fitting: these are the only components that will remain from the whole brake system, and I am going with silicone brake fluid so I need them to be ultra clean.
As the car is on sturdy jack stands, I will change the trans oil pan (for a bigger aluminum-ribbed one + new filter and fresh oil),
install the gearbox encoder for the Intellitronix speedometer,
change both upper and lower radiator hoses,
change engine oil and filter,
change the engine rubber mounts,
install a fancy front spoiler (yes, I went with the Ch**y Ca***o option
) and some round chrome fog lights under the front bumper, the spark plugs, the ignition point, radiator cap, install the Intellitronix oil pressure sender, water temp sensor, route a wire to the coil for the tachometer feature of the gauge cluster, etc.
At the same time, once the dashboard will be done, I will reinstall the carpet (including a new layer of deadening material, and an additional layer of underlay), new bolts for the safety belts.
I asked a friend of mine who is a professional upholsterer an estimate for front bench and back seats (which are currently different), and some leather on the brand new Grant steering wheel: I am hoping a very special friendly price
Later on (maybe this next winter), I will have the door panels and quarter panels reworked too. I am not obsessed with the origin, but I asked for a period correct look...
So, I'm back to my rugby game on tv (it's 10pm here), have a nice day
