hi
here's what I ve done, I've swapped out the org slant six for a 318. the connector on the new auto trans is on it (three wire, brown=neutral sw, white and violet=reverse sw, or so I believe) my problem is I don't see where to reconnect the reverse wires to the body wiring (neutral sw goes to teh starter relay). I expected to see two wires at the bulk head connector on the right side, top two right hand wires, but when I look, there's nothing there. would it be in the coloun or something?
Thanks
Thanks
