68 Valiant Possible purchase
acastro22
SoCal
Hello! Happy holidays and a merry Christmas to everyone.
Was looking into purchasing this 68 valiant inline 6.
Owner says it makes a tap or a thunk when turning the wheel. Any ideas of what that could be? Thank you in advance
could be anything from a loose bolt to a waxed ball joint or broken frame.
more than likely it's just something worn out in the front end.
Loose or worn out wheel bearings.
Easy to check, grab the top of the wheel and rock it back and forth, listen and feel to/for clunks.
If it has a sway bar the end links and supports could be warn out or missing.
Jousting the front end could recreate the clunk,
Turning the steering wheel back and forth a few degrees and look and listen for clunks
