Today at 4:19 PM #1 A acastro22 Member Joined Dec 18, 2024 Messages 22 Reaction score 9 Location SoCal Hello! Happy holidays and a merry Christmas to everyone. Was looking into purchasing this 68 valiant inline 6. Owner says it makes a tap or a thunk when turning the wheel. Any ideas of what that could be? Thank you in advance
Today at 4:24 PM #2 J junkyardhero FABO Gold Member FABO Gold Member Joined Jan 23, 2005 Messages 8,782 Reaction score 14,193 Location Los Angeles could be anything from a loose bolt to a waxed ball joint or broken frame. more than likely it's just something worn out in the front end.
Today at 4:47 PM #3 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,275 Reaction score 16,664 Location Northern Colorado Loose or worn out wheel bearings. Easy to check, grab the top of the wheel and rock it back and forth, listen and feel to/for clunks. If it has a sway bar the end links and supports could be warn out or missing. Jousting the front end could recreate the clunk, Turning the steering wheel back and forth a few degrees and look and listen for clunks
